is there a way to change Rotate Axis
   9436   6   0
is there a way to change Rotate Axis?
not Pivot position, does houdini has a thing like Maya Rotate Axis(under Transform Attributes)?
You can use the ‘ key to reorient the handle any way you like. Hit ’ again to reattach it to the geometry.
Wolfwood
thank you. but that didnt work. since I rotate the handle, the geometry is in same position and rotation. ' key seems only rotate the handle not the geo.
On object level use the rotate channels, on sop level use a transform sop…
Pagefan
I mean rotate Axis not rotate channel
(') was really useful to know :-)
there is easy to use shortcuts page somewhere ?
http://www.sidefx.com/images/stories/blogs/houdini9_blog/h9_quick_ref_card.pdf [sidefx.com]
It's for H9 but guess most of the stuff still works (to some extend).
