So can anyone suggest some methods of making geometry glow when rendered? For example if I wanted to do a magical effect, and have a nice particle system glow different magical colours..or something..
I'm thinking this sort of thing might be easier to achieve in 2D, duplicating a sharp render and blurring it etc then compositing it over the original render etc. to make a glow. Although I have a suspicion that if I find a way to make stuff glow nicely in the render I might have more control over the look.
Does anyone have any suggestions?
Making things glow
17434 5 5-
- Dean_19
- 322 posts
- old_school
- 2540 posts
This question comes up frequently.
The general consensus answer is to do it in comp as it is a “lens” effect. It offers you the most control. Just search the SESI and OdForce forums for more info.
The only motivating factor for doing in render is if the glow was a bloom effect in a local atmosphere to the object that is emitting light. If that is the effect you want to achieve, then surround your object with volume data and render it that way.
- Dean_19
- 322 posts
Hey Jeff,
Thanks for replying and for the hip file.
I seem to be having trouble getting it to render. I am using 11.0.469 and I get the following error in my shell:-
mantra: Error loading geometry /obj/platonic_object1/switch1 from stdin
I tried the scene in a different build of H11 also (11.0.406), but I get the same error. I've had this before with H11 in scenes where the isoOffset sop is used. Is anyone aware if there is a bug?
- JColdrick
- 4140 posts
- capitanoseye
- 1 posts
old_school
Do you have a modern answer for this in 2019?
- toadstorm
- 414 posts
It's no different now. Do the glow in post, or make a volume that surrounds your object and light/render that volume with the object.
