I just wanted to find out if anyone has tried to fracture a lot of geometry with the new fracture tool in H11. I am finding it extremely slow in processing simple fractures , default settings and inputting points generated from a volume.
Rob
Voronoi Fracture in H11
6310 5 0-
- circusmonkey
- 2624 posts
- johner
- 826 posts
Hi Rob,
Can you give any more detail on your geometry? I've run some pretty high resolution geometry through it. The underlying VoronoiSplit SOP is multi-threaded and should perform pretty well, although it can be a bit memory-hungry.
I could probably generate some fracture times for “standard” geometry like the Stanford bunny or dragon if that's helpful.
And just to be clear, you're talking about SOPs, here, right, not dynamic fracturing?
Edit:
Try the attached file, which just uses the VoronoiSplit SOP and bypasses all the group creation, clustering, whatnot in the VoronoiFracture SOP, just to make sure that's not the problem.
This is a torus with about 1600 polys, which fractures into 500 pieces in about 1.5 sec on my machine (which is pretty fast - the machine that is).
Edit:
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- johner
- 826 posts
circusmonkey
While I am here is there any way to get the fracture tool to output point groups ?
Do you mean that instead of primitive groups called “piece0”, etc. you have point groups?
You can take over group creation by turning off “Create Output Groups” on the Groups tab, then turn on “Keep Internal Attributes” on the Attributes tab. That will give each primitive a “piece” attribute. You could AttribPromote that to points and Partition to create point groups.
Is that what you had in mind?
- Ratmann
- 110 posts
