Hi
I have a problem with half of mine character. half of mine characters polygons is pointing inwards.
So when i take it into a engine i can't se half ofthe character, and i can see the whole the other side for the inside.
How do i change the direction of the polygons?
many thx Robin!
Direction of a polygon
15249 16 2-
- Robin0217
- 50 posts
- ultraharmonizer
- 63 posts
- tamte
- 9380 posts
- Robin0217
- 50 posts
i tried Facet sop/Orient polygons and Reverse SOP but i don't work. when i take Facet SOP at my OBJ nothing happed, and when i i take reverse SOP the right sdes polygons change and go outwards. but the left sides polygons go inwards. Reverse SOP did what you said but Facet SOP did nothing.
does it matter if i have cimbinded some OBJ togather or should it make the same result?
- pclaes
- 257 posts
Perhaps try a clean sop -> orient polygons and follow it with a reverse if you need to. Then a facet to compute your normals.
- Robin0217
- 50 posts
- digitallysane
- 1192 posts
- Robin0217
- 50 posts
when i take the facet SOP and put Orient Polygons on, the body turns out right but face don't. and when i turn on Consolidate Points Fast nothing happend.
Pre-compute Normals and post-Compute Normals did do anything.
it's always some part that works with facet SOP and some parts of the character that don't.
- digitallysane
- 1192 posts
- Robin0217
- 50 posts
i can't do that the model is for a private person who does not want it shown to anyone.
Let me explain a bit more about the model to give you a cleare view:
First of i made the characters left side fully completed and then i mirrored it after that i added some more detail features and finally i combined it all into one mesh/object.
I have a idea that i can go back in my save files to the stage before i combined it and change it there (not a very large work a round a fully managalbe)
Or do you see that as a possibility?
Kind regards
Robin
Kind regards
Robin
- digitallysane
- 1192 posts
- Robin0217
- 50 posts
- Robin0217
- 50 posts
- old_school
- 2540 posts
The Mirror SOP by default also reverses the primitives so the primitive normals are properly handled. You “should” have no issues.
Let's step back, wayyyy back to the beginning.
Are you actually looking at Primitive Normals or Point Normals? Are they Blue or wine red? Blue = Point Normals. Remember that SOPs preserve all geometric attributes in most all cases. This means that pre-formed Normals will keep their orientation after countless reverses or any other destructive operations. This is a very very good thing btw and is a core behaviour in SOPs.
You can't see the mirrored half. That screams to me a point Normal issue. Maya files import in to Houdini with point Normals present. Just append a Point SOP right after the File SOP and in the Normals parameter, choose the menu option “No Normals”. This removes the point normals. See if that works.
One problem that arises from character Models imported from Maya/Soft/Lightwave is bad data. I frequently find duplicated primitives and degenerate wing-edged polygons in many a Maya/Soft/Lightwave model. These degenerate polygons don't play nicely with many operators.
Another issue with orienting polys is unshared points. If you want to use the Facet > Orient Polygons technique, you have to ensure that points are shared and that there are no degenerate polygons in order for it to work reliably.
One way to detect degenerate polygons is to use the Measure SOP and measure by area. Degenerate polys generally have zero area or very very small areas so you can identify them that way. I don't know if the Clean SOP does that.
- Robin0217
- 50 posts
Yes i am looking at the primitive normals im sure.
when i take on (no normal) in the parameter in the point SOP, should i a differense at the obj then? I don't see any differense.
and the same problem come. Every thing have the right direction at all primitive normals exept for the head and the left hand.
I did know some thing about the measure SOP so thx alot. I could use that one.
- Robin0217
- 50 posts
- Robin0217
- 50 posts
