using relative paths in op:
   17101   7   4
This may be a simple syntax question, but is there a way to use a relative path with the op: keyword? I am trying to point to a COP operator, and I can do this successfully with absolute paths but will not work with relative paths
I know I have done this is the past with expressions such as op:`opinputpath(“..”, 1)` in cases where I have a node wired as an input. However, when I tried to use opfind, I had no success
Any help on this would be huge!
-G
Hi Grey,
You can use the opfullpath() expression for this.
op:`opfullpath('..')`
cheers,
-j
That worked perfect! Thank you!
-G
How can I link the output from a COP2 network to a texture map in a normal mantra-material in Houdini 15.5.480 ?
The method with the “op:`opfullpath('..')`”-function doesen't seems to work in this version.
xXchrizzoXx
That's my question exactly. Any takers?!
This is probably not the right way to do it, but it works:
op:/img/tex/OUT
Hello Konstantin,
Thanks for your suggestion.
This is what I get. Actually, I get that whether I do your “opimg/tex/OUT” or the standard “opimg/img1/OUT”
Oddly, my material turns this light pink as opposed to the standard grey, either way, when I try to call in the texture from null node.
What am I missing, or messing up?
PS. The smilies are from the colons + forward slash.
Edited by marque_pierre - Sept. 11, 2017 10:40:44
op: references don't currently work that way in /mat, as only parameters on materials are scanned for references to external nodes.
You will need to encapsulate your material network in a builder node, and then use a parameter vop to pass the filepath to the texture node. Then for the value on the filepath, you can put the op reference. (note: putting the op reference directly on the parameter default value does not work)
