lissajous figures & harmonograph
   8176   5   1
I've been learning Houdini with Apprentice and this draws the lissajous figures and figures produced by the harmonograph. Press Play to run the simulation. Play with parameters in the vars node.
I've tried to comment the nodes –> I'd be keen to hear what you think of the skinning method used, ideas to use this a jumping off point to learn dynamics & shading in Houdini.
thanks,
jag
Edited by - Jan. 3, 2013 09:13:52
lissajous_harmonograph.hipnc (90.5 KB)
din is noise: http://dinisnoise.org/ [dinisnoise.org]
hmm just found a bug in my harmonograph expressions will correct and update the .hipnc file. the lissajous is fine (i think
–jag
Nice job.
I was playing with the harmonograph and it seems that a complete picture is not generated until after 362 frames.
I'm relatively new to Houdini. How could this be easily modified to generate the appropriate harmonic image in less frames, such as every frame?
Thank you for your time.
that's cool! thanks for sharing it.
12++
+++ ability to speed up drawing.
+++ sine & cosine functions modeled as bezier curves - edit them on the channel editor for weird warped drawings.
happy new year!
lissajous_2013.hipnc (140.0 KB)
Thanks, always good to see the set up others use
My blog
http://52weeksofhoudini.blogspot.co.uk/ [52weeksofhoudini.blogspot.co.uk]
