Motion blur ???? particlefluidsurface
   4107   4   0
Hi
I have meshed my particle sim using particlefluidsurface SOP but now when i render i dont get motion blur i guess it because the topology of mesh changes in every frame
Is there any work arounf for this…
thanks
Arjun
In your particlefluidsurface sop, attribute tab, specify “v” to sample the velocity attributes from your particles.
You can also enable the “filter attributes” on the filtering tab.
Should be fine after that.
Adrien Toupet - https://www.youtube.com/@AInVFX - https://www.ainvfx.com [www.ainvfx.com]
well i already have both velocity and filter enabled still it renders without motion-blur
On your Mantra node, turn on the Allow Motion Blur checkbox on the Sampling sub-tab of the Properties tab.
Did you try “Geometry velocity blur” in geometry-render-sampling tab?
http://vimeo.com/user7871222 [vimeo.com]
