Missing Icons under Ubuntu 11.04
   17360   21   6
build apprentice 11.1.67
OS ubuntu 11.04
hardware Dell Precision M6300
tried and failed
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=82774&highlight=#82774 [sidefx.com]
any advice welcome
Kind regards
John
For starters, it would help to show which error you're getting, and what exactly from that other thread you have done. There's about 3 things in that thread.
Fair play, late night posting etc sorry..
All I have is white squares on all gadget buttons.
I followed the fix and received no unexpected
error message, yet restarting produced no
results or changes.
John
fix I attempted
Here's an idea to try if you're willing to modify your installation. It probably won't work though. And I can't test since I don't generally run Linux. Smile
Code:
$ cd /opt/hfs10.0.465
$ source houdini_setup
$ echo $HOUDINI_BUILD_KERNEL
(make sure this mentions amd64 if you're on a 64-bit OS)
$ cd hsvg
$ ./hsvg $HH/help/nodes/images/fov.svg -o/tmp
Confirm that this brings up the libgio error. If there's no error, then something else is wrong. Assuming this brings up the libgio error, we can try to figure out which libs are causing the problem:
Code:
$ sudo mkdir oldlibs
$ sudo mv lib* oldlibs
This moves all the libraries that might conflict into the oldlibs directory so that they are no longer used. Ok, now we try using hsvg again:
Code:
If the hsvg command produces no errors or warnings, then we're done. We should remove the icon cache before restarting houdini:
Code:
$ cd ~
$ rm -r ~/houdini10.0/config/Icons
$ houdini -foreground
I suggest trying the fix some more. It always solves it for me. A native gcc 4.5 build would be nice tho.
Drive, monkey, drive!
You think it may surrender and give back my icons
Would there be any software on linux similar to ‘snoopdos’
(from Amiga Days)
I've reinstalled houdini a couple of times on ubuntu
to no avail and my priority is using not developing it.
So like to avoid continued repetition
john
Reinstalling Houdini shouldn't be necessary unless you're trying different builds.
The icon cache lives in /home/username/houdini11.1/config/Icons, and it's generated when you start Houdini (if it's not already present).
The basic idea is to fix hsvg, remove the corrupted icon cache and restart houdini so that it's generated again. (with icons hopefully)
What output do you get from the following:
cd /opt/hfs11.1.67/hsvg
ldd ./hsvg-real
When you start houdini from the terminal, do you get any output?
Also, when you followed the directions from the other thread, did you get the libgio error mentioned?
www.alan-warren.com
I do have simmilar problem on OpenSuse 11.4.
Houdini starts without problems, all icons are OK. But when I load file with rig I made and press play to see animation, BOOM ! all nodes have white squares and it outputs .png errors. But when it starts it doesn't.
Edward's tip doesn't help.
Edited by - Oct. 9, 2011 01:10:45
I have Icons
I moved the libraries manually from oldlibs back into
/opt/hfs11.1.67/hsvg/
one by one
left in old libs
libbz2.so.1.0
libcairo.so.2
libcroco-0.6.so.3
libexpat.so.1
libfontconfig.so.1
libfreetype.so.6
libgdk_pixbuf-2.0.a
libgdk_pixbuf-2.0.so.0
libglib-2.0.so.0
libgmodule-2.0.so.0
libgobject-2.0.so.0
returned to hsvg
libgsf-1.so.114
libpangoft2-1.0.so.0
libpng12.so.0
librsvg-2.so.2
libxml2.so.2
why those I don't know
come on mods sort ya spam out
Out of curiosity. Do you have all the libs you moved back installed in your system?
Erik_JE
the particular libs were in
after installation. This patch/fix moves them
all to a new folder oldlibs.
this is meant to work but in my case it didn't.
so one by one i copied them back until it worked.
I expect these libs do exists in the OS but Houdini
must look here first. Someone with more experience
than me will have to you if i'm right because i'm
still in a learning curve.
john
JohnWorthington
All I have is white squares on all gadget buttons. I followed the fix and received no unexpected
error message, yet restarting produced no results or changes.
Did you replace “houdini10.0” with “houdini11.1” in the instructions? Did all commands behave as expected? I assume that you're running a Houdini 11.1 build. Ideally, you give us a full log of the commands you actually ran along with the command results.
Make sure that you also turn off Desktop Effects (aka Compiz).
houdini10 never started on mine so I waited until I started at Uni before installing 11.1.
To solve the icon problem I followed the posted and command previously posted on this thread.
I solved my problem by moving libs With Krusader and restarting.
john
JohnWorthington
I have Icons
one by one
left in old libs
libbz2.so.1.0
libcairo.so.2
libcroco-0.6.so.3
libexpat.so.1
libfontconfig.so.1
libfreetype.so.6
libgdk_pixbuf-2.0.a
libglib-2.0.so.0
libgmodule-2.0.so.0
libgobject-2.0.so.0
returned to hsvg
libgsf-1.so.114
libpng12.so.0
librsvg-2.so.2
libxml2.so.2
Thanks John! I was having the same problem. Now everything works fine!
FabianoBerlim
Makes the results worth posting thanks
I'm putting off upgrading to ubuntu 11.10 as I want it to stay working..
thx for the fix!
just installed ubuntu 11.10 & houdini apprentice > had the same problem and this was a quick fix!
thx for sharing
lari
lari
larikaram
thx for the fix!
lari
Welcome, might install 11.10 myself now
John
*sigh
Linux never fails to disappoint. Thanks for this solution!
JohnWorthington
I have Icons
one by one
left in old libs
libbz2.so.1.0
libcairo.so.2
libcroco-0.6.so.3
libexpat.so.1
libfontconfig.so.1
libfreetype.so.6
libgdk_pixbuf-2.0.a
libglib-2.0.so.0
libgmodule-2.0.so.0
libgobject-2.0.so.0
returned to hsvg
libgsf-1.so.114
libpng12.so.0
librsvg-2.so.2
libxml2.so.2
I'm coming late to this party, but having very slightly different problems.
I'm running Redhat EL 4, houdini11.1.201 and after selecting the same libraries as the last post, I get:
/opt/hfs11.1.201/hsvg/hsvg-real: error while loading shared libraries: libcairo.so.2: cannot open shared object file: No such file or directory
When I run ./hsvg $HH/help/nodes/images/fov.svg -o/tmp
Does this mean that libcairo isn't installed in my system?
Maybe. It could be that you don't have it installed and/or libcairo.so.2 is named differently in RHEL4, and/or you don't have the matching 32-bit vs 64-bit version of the library installed.
Since you're working with a different Linux distribution, the library changes you need could be totally different.
Finally, I hope we've fixed this issue for good in the latest H12 daily builds where I think we finally ship with exactly the right set of libraries along with hsvg that should never require this hack again.
