capture geometry
   3774   2   1
if i apply the ‘capture geometry’ and select type: regions,
later, after couple of steps ahead, how do i change the type to :proximity? how can i go back to capture geometry OP?
ussually , i have to go to sop state, delete the previous capt.geometry OP and apply new capt.geo OP .is there any short way like for example : popup menu to select between region and proximity?
clay~
if I were changing from regions to proximity I'd want to be down in sops to make sure everything cooked through properly…
Training Lead
www.sidefx.com
To do this in the object viewer:
1. Tab > Capture Geometry
2. In the parameters toolbar (Viewer Controls?) above the viewer, change the method from Region to Proximity. Change the method from Append to Replace.
3. Select your geometry object. Right-click if secure selection is turned on.
4. Select your root hierarchy object. Right-click if secure selection is turned on.
