Geometry renders with wrong transform
   4785   4   2
(I couldn't find a thread with a similar problem as I am having)
My problem is that my geometry appears to move when I attempt to render it as I am inside the geo's network (assuming that the transform node of the geo has been moved).
For example:
-I created a simple box (or default file node) and moved it <1,0,1> in world space using its scene transform node. This renders fine. (I'm using the Scene View ‘camera’ to render to MPlay)
-Then I dive into the geo's node and render here. The render presents the box at around <2,0,2>.
-Then I go back up /obj level, try rotating the transform node around Y at 45 degree increments, and then diving back down the geo network each time before I render. The result is the geo being positionally placed around around <1,0,1> (radially), though no actual rotation on the geo is being applied.
I'd like to know if this is a known bug, or if there is a way to circumvent this behaviour. I've already positioned up some geometry in my small scene and proceeding to texture it; that's why I'm diving down to geo level where my shopnet, uvprojects, and materials are located. But this behaviour is making my objects a moving target.
Many thanks!
Please post up a simple scene file showing the problem.
Rob
Gone fishing
A scene file will be most helpful.
Though, for proper testing, I recommend putting down a camera and a mantra node and use those for rendering, rather than View:Mantra
@silvina: Thanks heaps for your advice: by creating a new camera and using that to render the bug is no longer present.
But for completeness I attached the scene file nevertheless because I managed to reproduce the problem and some other notable features cropped up. It took me awhile to be able to reproduce it; I still don't know exactly what causes it, but I put it down to a ‘state’ problem, whereupon I load a particular ('suspicious') scene and it ‘corrupts’ Houdini to exhibit the bug as long as the session is open. If I close Houdini and re-launch, the bug doesn't show up.
-The attached scene was created in that same Houdini session where the bug started happening.
-The scene was tested by re-launching Houdini and loading the scene; the bug is there when using a Scene View camera.
-In addition, the scene, very strangely, loads very slowly, which may or may not have something to do with it. Opening the hipnc file I notice that there are named referenced to my original ‘suspicious’ scene that shouldn't be there.
-Again, rendering with a new camera (non-Scene View) seems to correctly render the object.
Thanks Rob and silvina for taking the time.
supertemp2.hipnc (84.7 KB)
Hmm. Just seeing something like this too.
Can't stop it from happening by adding a new camera though. Also, we get a full scene render from within an object, as well as the double transform issue.
:shock:
