Removing splits in surface.
   3920   1   1
Hi all, is there a way to remove a split in a surface? I have a distorted surface, not made with the polysplit sop but having the same result. I need to remove it. Any ideas would be great.
Thanks,
JT
By split do you mean a hole in the surface? If so you can use PolyStitch or Poly Cap.
If you mean some random edge that you want to get rid of try the Dissolve sop.
jim.
