I've ran into problem with expressions and after hour of experiments im giving up: i created a node and added 4 parameters to it: 2x op paths, string and float.
What i want is to enter path in “sop path” param, get full path with channel name in “test string” param and get value of that channel in “test float” param. Op paths works as expected, after some time i figured out how to build full path in “string param: chs(”p2“)+”/tz“ + key on that channel.
Now - how to get the actual value of that channel?
Tried ch(ch”tstr")), but it doesn't work.
Any suggestions?
accessing sop paths and channels in expressions
5136 5 1-
- Mudvin
- 66 posts
- asnowcappedromance
- 512 posts
- Mudvin
- 66 posts
Here is it. Basically i'm trying to create a line between 2 points, but since a “line” sop doesn't have any inputs, i have to use expressions to access geo translate channels. The reason i'm doing it that way is that i want to make a preset/hda to reuse it later by just changing sop paths.
wbr, Mudvin
- 512 posts
- Mudvin
- 66 posts
- Mudvin
- 66 posts
By the way: is it possible to access “composite parameters” in houdini, like in maya where you can do “setAttr box1.tx 0.1” or as well “setAttr box1.t 0.1 0.2 0.3”?
At the moment i have quite a long multiline python expression, and i have to repeat it with minimal differences for tx/ty/tz.
wbr, Mudvin
