This is an embarrassing question.
How do you get strong specular highlights on a transparent object using the Mantra Surface shader?
Am trying to render a clear, thin plastic. No refraction. Have strong specular highlights before adding opacity settings. Once opacity is added the specular highlights fade away also.
I must be missing something ridiculously simple here.
Specular highlights on trasparent object
3902 2 2-
- fgillis
- 157 posts
- zdimaria
- 390 posts
- old_school
- 2540 posts
Mantra Surface has the Conserve Energy option on.
This means as you decrease the Diffuse intensity as you make your surface more transparent with the Opacity parameter, you have to increase the Specular Intensity in the Reflect Lights tab.
Read the Diffuse Intensity and Specular Intensity as a percentage of light reflected and the remainder is the light absorbed by the material.
