I'm here at school and we completely changed our servers and systems we work on, so now all my paths in houdini for my geometry is looking in the wrong Path location. Is there some python script or automatic way that houdini can find all my geometry based off of where one is? Adobe Premier has this feature and does it automatically.
The geometry file location is wrong and the node is red because it cannot find it. I really don't want to have to reattach all the geometry for this and all my other houdini files. Any help?
Moved geometry file locations: How to redirect path ?
6927 8 3-
- garretthoyos
- 43 posts
- xmetallicx
- 1 posts
- Erik_JE
- 300 posts
- Dean_19
- 322 posts
- garretthoyos
- 43 posts
It was dumb of me to not use $hip or $job. Unfortunately at the time I didn't think of this solution. It is currently looking in
$HOME/Desktop/grape_geo/v1.obj I wish it were looking at $HIP instead so I wouldn't have to worry about this if something ever gets moved again, but a Python script idea would be helpful, all my files are this way. :?
- goldfarb
- 3465 posts
- Dean_19
- 322 posts
It seems from the example path you gave and from the screen grab that the name of your geometry file matches the name of the node which is filing it in.
In this case a quick way to do it would be just to box select all of them and re-type the path in as:-
$HIP/Desktop/grape_geo/$OS.obj
or
<whatever the new path of where your geo is kept is>/$OS.obj
If you really want to use a python script to do it, one way might be something like:-
sel = hou.selectedNodes()
for i in sel:
print i
i.parm(“file”).set(“$HIP/Desktop/grape_geo/$OS.obj”)
Provided you are using normal file sops to file in the geo, and you select the file nodes you want to change the filepath of before running the script (you don't have to do it this way, you could do it by searching for any file nodes in your scene for example).
or
for i in sel:
print i
- garretthoyos
- 43 posts
- Dean_19
- 322 posts
