how to disable node auto-connect temporarily ?
   4880   3   0
Hi , when working in a tight space and many nodes, most of the time when moving the node around, i run into problem when i accidentally activate the autoconnect . This is very annoying but i don't want to disable it , in some case it will be usefull but is there any way i can turn this off temporarily ? i mean like some modifier key to press to disable this feature until i release the key. Or any other trick ?
Andi
if you mean Drop-On-Wire functionality you can toggle it with E key
tamte
Thanks, that's exactly what i'm looking for.
For those who needs, in newer version toggle it with Ctrl+8 (Tools/Allow Dropping Nodes On Wires)
Lei Wu
Technical Artist / Parametric Architect
Toronto
Open to work
