Jelly render
   11060   7   2
An exercise in rendering, something I don't get to do often in our huge pipeline…
Basic comp and color correction, not so realistic, but that's my taste I guess. Photon map flickers a bit but it's kinda low-res so…
https://vimeo.com/62106087 [vimeo.com]
Cheers
Toronto - ON
Wow, that's gorgeous. The crisp highlights and subtle color blending are thoroughly convincing.
Chronon
Wow, that's gorgeous. The crisp highlights and subtle color blending are thoroughly convincing]
Thanks! Glad you like it!
Toronto - ON
Agree,the rendering of this animation is excellent!
cloud render–Fox renderfarm
(http://www.foxrenderfarm.com) [foxrenderfarm.com]
2,000 servers,each has 2 Intel Xeon E5645 processors,24-64GB RAM.
I'm re-rendering with higher photon cache to get rid of some artifacts and also a better sim to eliminate the extra bounciness… It's looking much better so far.
Cheers
Toronto - ON
Wow Rafael! great job man!
Do you use a mantra surface for jellys, or other shader?
Congrats!!!
My Vimeo: https://vimeo.com/user5877906/videos [vimeo.com]
Thanks, Paulo
Believe it or not it's based on the built-in glass shader, but it could have been the mantra surface. The only reason it isn't is that I needed to mess up with the internals of the shader a bit and the mantra surface was a bit overkill…
Cheers
Toronto - ON
Nice tests rafaels keep them coming.
Juan
