Multiple OpenCL devices - how to select
   13232   7   2
Hi guys,
so, afaik, Houdini is only using a single OpenCL device at the moment. The problem is, I have two (a 680 and a Titan) in my workstation, and for obvious reasons I'd like to make sure that the Titan is being used for computations. However, I have yet to find a setting anywhere where I can choose the device - is there one?
Michael
There is a family of environmental variables controlling OpenCL related behavior, from which HOUDINI_OCL_DEVICENUMBER might be the one you are interested in.
There is also *_DEVICETYPE, *_VENDOR among others.
Awesome, thanks, I'll give that a try on Monday
Cheers
Michael
You can also do this in the nvidia drivers. just select the right card for opencl
Help>About Houdini and the show details, scroll down until you see opencl, there you can check if it worked
Also, if you have a Telsa+Quadro combination, Nvidia's Maximus feature will kick in and automatically route compute and graphics traffic to the right card. This doesn't work with GEForce cards, though.
Has anyone got the HOUDINI_OCL_DEVICENUMBER variable working?
There is an AMD card and Nvidia in the machine/Windows7. The Nvidia is device 0 and the Amd is device 1. When I try to switch to the AMD there is an error -33. I'm using 'set HOUDINI_OCL_DEVICENUMBER=1" to try to use the AMD card
The only way I have got OpenCL onto the AMD is to rip the Nvidia card out of the machine. It then works perfectly
Houdini 12.5.517, Windows 7 64bit
MartybNz
You probably also need to set HOUDINI_OCL_VENDOR when they're both in the machine, as it's picking up the Nvidia one. When it's working without NVIDIA, find the exact vendor string as reported in Houdini About…, then set the environment variable to that. I believe it's:
Advanced Micro Devices, Inc.
with all the spaces and such.
The device number is per vendor, so you probably don't need to set the DEVICENUMBER once the VENDOR string is working.
The OCL environment variables are the following:
$ hconfig -a | grep OCL
HOUDINI_OCL_DEVICENUMBER := 0
HOUDINI_OCL_DEVICETYPE := ‘GPU’
HOUDINI_OCL_MEMORY_POOL_SIZE := 0.125
HOUDINI_OCL_PATH := ‘<not defined>’
HOUDINI_OCL_REPORT_MEMORY_USE := 0
HOUDINI_OCL_VENDOR := ‘<not defined>’
And you can get help for each one with:
$ hconfig -h HOUDINI_OCL_VENDOR
HOUDINI_OCL_VENDOR
Specifies the platform vendor to choose when creating the OpenCL
context Houdini uses for OpenCL processing.
Thanks johner - that works perfectly.
