Python SOP get channel data CHOP
   10839   21   1
Hi guys!
I got stuck again, with a similar problem, this time trying to get a value for a sop point attribute at a given frame.
Channels
channel = hou.node('../fileChop/OUT_AMPLITUDE')
value = nTrack.tracks().evalAtFrame(hou.frame())
Parameters
parm = node.parm(“tgl”)
value = parm.evalAsIntAtFrame(hou.frame() - 1)
Attributes
attr = geo.pointAttribs()
attr.evalAtFrame????????something maybe?
Is it possible to find out the value of a point attribute at a given frame? Cant find the correct syntax for it anyways, my solution was, hou.setFrame(myFrame) -> Evaluate attribute…
But I wasn't to happy with that solution.
well thanks again
I'm not sure that's possible through python
maybe just import that attribute to chops with Geometry CHOP and sample that using mentioned method for chops at certain time
even if it was possible to sample attribute point value at certain time directly it would be probably slower than chop method considering that you may want to sample thousands of points every one at different time, which is pretty quick from already computed chops but slow if for every point the whole geometry needs to be cooked again at different time
another problem may be changing topology, which is pretty common in sops so point value at different time may be inconsistent or completely non-existent
