Hi guys.
(Q) where is “Source Apply Node”of DOP in 12.5?
Thank you for helping.
Tony
where is Source Apply Node in 12.5
5282 1 0-
- sisqosnew
- 57 posts
- tamte
- 9738 posts
the preferred sourcing workflow has changed in H12
the generation of source volumes happens in SOPs using Fluid Source SOP
then it is brought to DOPs using Source Volume DOP
just use some of the Shelf Tools and you will see how it's used
you can always use old Apply Source if you unhide it (opunhide Dop sourceapply) even though new Source Volume is recommended
or there is always traditional source relationship
