H 11
   6465   12   2
Are there any ways that we can use H 11,
I have tremendous problems in using H12 to work on my files done in H 11,
I believe there are serious problem in comparability between H 11 and H 12.
Can any one help me.
Sidefx blocked using all the previous versions.
on the FTP you can still download the latest H11 build.
ftp://ftp.sidefx.com/public/Houdini11.1/
I tried but, could not
Can you help me further?
that is weird. :roll:
not sure why it wont work for you.. i just tested it and it downloads fine here.
Which browser/os are you using?
here the direct links:
windows:
ftp://ftp.sidefx.com/public/Houdini11.1/houdini-11.1.latest-win64.exe
mac:
ftp://ftp.sidefx.com/public/Houdini11.1/houdini-11.1.latest-macosx_x86_64_gcc4.2_10.7.dmg
linux:
ftp://ftp.sidefx.com/public/Houdini11.1/houdini-11.1.latest-linux_x86_64_gcc4.4.tar.gz
you can also try in the command line with wget <link> or some ftp client. and connect to ftp.sidefx.com
also you might try to “ping ftp.sidefx.com” in the command line and see if you get a reply at all. else you might need to send an email to support and ask them.
Thank you very much, I will try it again.
Thanks a lot !!
I downloaded H 11.
But, there is NO license that I can install.
How can I use H11 trial version without installing license
H11 should run with an apprentice license. Just install, launch and provide your forum id and password to fetch the license and go.
Thank you very much Folks!
I did try it But, I still can not open H 11
It prompt “Install Valid License.”
Tried to install the licenses.
But, It can not be connected to the server.
There is No Valid license to install.
Id & Password box are greyed out.
here's a quick guess.
Run “HKey” (the Houdini License Admin Tool) and take a careful look at the output from View->Diagnostic Information option. Does it say you are using the locally embedded license validator, or hserver/sesinetd? You might need to change it to be local. Depending on which Operating System you're using, this can be changed manually by editing a txtfile (via Houdini Shell) called
$HFS/houdini/Licensing.opt
If you have:
licensingMode = sesinetd
try commenting-it-out & changing it to:
# licensingMode = sesinetd
licensingMode = localValidator
not sure this will solve the issue; it's just a suggestion.
be prepared to undo this mod!
cheers,
ben.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
Thanks a lot Ben,
I will try it soon and let you know how it goes.
Thanks again.
Steve
Do I need to connect to sidefx.com when I do this ?
I tried it But, it did not work.
I attached my H11 Diagnostic Info.
Can you review and help me further please?
Thank you
Steve
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Mon Sep 2 16:13:18 2013
Local host name: yhkflys-MacBook-Pro.local
Local server code: bc202a09
Local ip address: 127.0.0.1
Number of servers: 1
License server name: new-host-2.home (new-host-2.home)
Server ip address: (could not look up server)
Reported host name: (unknown)
Reported host ip address: (unknown)
License server is running: No
License Administrator version: 11.1.388
Http proxy host: (none)
Licensing options file: /Library/Frameworks/Houdini.framework/Versions/11.1.388/Resources/houdini/Licensing.opt
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] No (ERROR: Could not connect to license.sidefx.com:80
(Are you connected to the internet? Do you
need to set an http proxy?))
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
Cannot connect to server new-host-2.home (240.41.15.0)- verify that sesinetd is running.
hserver -l output:
Hostname: yhkflys-MacBook-Pro.local
Uptime: 0:01:27
License Server: new-host-2.home
**WARNING**: Unable to contact license server (for 86 seconds)
Server Version: sesinetd4.x
Version: Houdini11.1.388
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
2,901,260 of 4,194,304 MB available
CPU Usage: 9% load
0 active tasks (2 slots)
licenses file:
* The local machine is not the server machine, so the licenses file
cannot be shown. *
