I'm currently trying to use a wedge and geometry rop to write my particle sim to disk. However when I'm trying to use $WEDGE in the naming, it just turns red and it seems there is no wedge variable (see image).
I've also tried underscores and also {$WEDGE} but it doesn't work. Does anyone know what I'm doing wrong? I've used a tutorial by Peter Quint for this setup and after checking about 10 times, I'm pretty sure I am setting it up the same way.
Any ideas?
I'm working with version 12.5.427
$WEDGE unknown
5939 6 2-
- jennehjenneh
- 14 posts
- AdamT
- 184 posts
- jennehjenneh
- 14 posts
No doesn't work either.
Because I'm only working with just a few random seeds I'm using the channel right now, that does seem to save the wedges in different files. Though I still don't get why it doesn't understand $WEDGE
showreel: https://vimeo.com/79698203 [vimeo.com]
- mbbuckley
- 47 posts
Well, its been 4 years, and now this problem has happened to me. Don't know if jenneh ever found a solution, but this is my first time using wedging, and I do not seem to have that $WEDGE variable either.
I'm in the /out context and on a geometry node. I'm trying to create cache directories based on the wedge number. In the output file parameter, if I type $WEDGE, it does not evaluate to anything. If I type it and middle click the parameter name, it evaluates to nothing. Also, if I just type $, a dropdown appears of available variables. Neither WEDGE not WEDGENUM are in there.
Any ideas as to why I do not have access to these variables? I'm on Houdini 16.5.439.
- jsmack
- 8178 posts
There is no such global variable as ‘WEDGE’ or ‘WEDGENUM’, that's why it doesn't exist. When running wedges using the wedge rop, a script sets the value before rendering each wedge. Until the script runs, the variables won't exist, and houdini won't know anything about them. If you want the ‘preview’ a wedge, in your interactive session, you can set the variable to some value using the textport.
run the “set” command in your textport to set the wedge value to something:
set -g WEDGE=mywedge0
set -g WEDGENUM=0
Edited by jsmack - May 24, 2018 23:53:08
- mbbuckley
- 47 posts
- michaelh99
- 5 posts
