POP slide/creep? H13
   19416   13   3
Hi
I'm trying to set-up a particle system where particles flow around geometry, sort of like your typical rain drop system.
I kind of imagined that POP Collision Detect set to slide would do the trick, guess not though.. I've also messed around with POP Attract, but I'm not really getting the expected results.
Prior to H13 with the old POPs I would use creep or cling.
am I missing something??
thx
Jason
fx and lighting @ rebelway
https://www.youtube.com/@jason_slab
anyone, I need to figure this out as well,
I tought if I put a popwrangle with
vector landpt; // declaring a vector
landpt = point(@OpInput4,“P”,@ptnum); //terrain connected to
then in a popvop import this as parameter then vector to float and connect second output( assuming this would the Y value) as the new height
but it does not work, I am not good with syntax , anyone has anyideas,
basically I am trying to keep particles on the ground
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
nevermind, figured it.
solution came after watching the https://vimeo.com/81611332 [vimeo.com] Houdini 13 Masterclass | Particles altough I am not sampling volumes but PCopen,
So whoever is interested the file is below
DopPop_Terrain_Follow.hip (273.0 KB)
Head of CG @ MPC
tricecold
That's Interesting solution :wink:
Rabiee.Sadjad@Gmail.Com
Just a simple UV lookup driven by age.
IG_doppop_terrain_follow.hip (210.4 KB)
jason|slab
Quite a critical bit of functionality, one hopes it will return soon without having code our own
Peter Bowmar
____________
Joker386
tricecold
I am open to all suggestions man
Head of CG @ MPC
Ilan Gabai
I am sorry I see the particles moving on the surface, but I didnt understand how man, can you explain a bit more
Head of CG @ MPC
Sure.
So basically it all happens in the pop net. The mountainy ground plane is a nurbs surface, and therefore has parametric uvs. Using a “primitive attribute vop”, you can get the world space position of the UV value. So if you give the U for example a rand($ID) value, it will scatter the particle along the surface's U in world space. And if you drive the V with the particle's normalized age, it will travel along the surface's V in world space (in the rand U's lane) over it's lifespan. Let me know if you have any more questions.
~Ilan
Or you can use the Popnet - Old and turn on Slide on Collision. Easy
Peter Bowmar
____________
pbowmar
jason|slab
agreed, agreed, +1 +1 …
Imre Tuske
FX Supervisor | Senior FXTD @ Weta FX
qLib -- Houdini asset library
http://qlab.github.io/qLib/ [qlab.github.io]
https://www.facebook.com/qLibHoudini [www.facebook.com]
Maybe I miss something, but don't do the trick just simple popcollisiondetect1 with Slide response and turning off Collide Relationship on merge?
Look at example file.
pop_slide.hipnc (705.7 KB)
well the problem in your scene is they stay on the surface indeed but they fall off, so like you said, they are sliding. They also keep their vector after the tip of a hill and fly a bit more until falling on the surface.
Head of CG @ MPC
pezetko
If you increase the Default Particle Size the particles don't fall off.
pop_slide_153_increased p_size.hipnc (325.4 KB)
