Hi, I'm having troubles forcing Houdini to use High DPI UI. I just installed the Apprentice edition on my new MBP and the UI looks pixelated, which is fine I guess. However when I change the “Global UI Size” option in preferences to “High DPI”, the UI does not end up being high DPI - it ends up getting a lot bigger and still pixelated (see attached screenshot).
The “Open in Low Resolution” option on Houdini applications is disabled. I'm using OS X 10.9.1 on a Late 2013 15" MBP with external GPU.
I know you're not supposed to get support for Apprentice, but this looks like a bug and I'd be grateful for any help.
H13 and Retina display
10694 13 0-
- gbernady
- 1 posts
- Unai
- 17 posts
- stu
- 252 posts
- anon_user_37409885
- 4189 posts
- malexander
- 5286 posts
Later OSX versions require that Apps state that they are DPI-aware, which H13 doesn't currently do. So it'll make the window much smaller, and just composite it into the desktop with a 2x scale factor. When the retina displays first came out and I added the High DPI UI size, I don't believe this was the case.
We should be able to get it Houdini running at a 1:1 pixel ratio when in high DPI mode, I just have a few dev pages to read up on
- Stalkerx777
- 183 posts
- Cyzor
- 181 posts
- malexander
- 5286 posts
- Stalkerx777
- 183 posts
- Unai
- 17 posts
twod
Houdini 14 supports high-DPI displays natively. There are enough minor issues with scaling in H13 in native high-dpi mode that we've left it disabled.
It seems the problem persists in H14: although the window frames show at high DPI, everything inside is still half resolution and scaled up, no matter which UI size I choose.
- mtucker
- 4565 posts
Yes, this is still an issue in H14. We have made some progress internally but still need to iron out a few issues (help browser and python panels). Once we have something we're happy with we'll have to evaluate whether it is safe to port the changes back to H14 or wait until the next release to make the changes available.
Mark
Mark
- Unai
- 17 posts
- malexander
- 5286 posts
- Unai
- 17 posts
It’s always great to hear from developers. Can’t wait for it to happen then!
