Houdini To 3dsmax
   7888   11   1
Hello Everybody
can someone tell me how to export Houdini's particles to 3dsmax.
NAIT ZLAY
back in the days I was using realflow plugins to exchange data, maybe now there is more options, but if you have access to them then they work nicely
tamte
ah ok i see , thanks you , but i hop we have others options to do it.
NAIT ZLAY
My knowledge is very sparse here but can you do it through krakatoa .prt files? see for example: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=130380&highlight&sid=684e4257a156f45852a9dc07c68086c7 [sidefx.com]
I think that page also mentioned Alembic, but I'm not sure if 3ds max supports alembic yet.
edward
hmm..interesting.im looking for the realflow houdini13 plugin.. i think thats not exist yet . :cry:
NAIT ZLAY
alembic should be works perfectly.
Lead FX @ Jellyfish Pictures
Ivan Pulido Suarez
You did it ?
NAIT ZLAY
alembic only works if you have a plugin in max to read the alembic. Crate from Exocortex works pretty good. If you can't afford the plugin, the prt exporter works fine too.. although i think you need to have Krakatoa in max..
robonilla
ok, i see , but i dont think that we have a PRT exporter for H13 ?
NAIT ZLAY
As Edward pointed above this guys developed one,
https://github.com/FictionIO/PRTRop [github.com]
The compiled version there worked for 12.5 as well, you would have to try it on 13 or probably compile or ask someone who can compile it for 13.
robonilla
ah , Nice , thanks
NAIT ZLAY
robonilla
i find an officiel one : https://github.com/ThinkboxSoftware/HoudiniPRTExporter [github.com]
but still not for H13
NAIT ZLAY
