VCC -X sop
   4394   3   0
Hey everyone.
I am working through the Wrangle Workshop.
Ari uses the Shell command “vcc -X sop” to call all possible functions.
My Shell returns this:
Henriks-MacBook-Pro:~ henrikgieselmann$ vcc -X sop
-bash: vcc: command not found
Any Ideas what I am doing wrong?
Thanks so much in Advance!!
Greetings!
Henrik
From the Applications menu, are you starting the Houdini terminal?
When I am in Houdini I go:
Window - Shell?
Is that incorrect?
No, I was thinking from your OSX dock's Application menu. If you do it from Houdini's main menu Window > Shell, I would expect vcc to be found there too though but I don't usually run it from there.
