Help! Smoke Rendering
   2967   1   1
This is probably an extreme noob question, but I am trying to create billowy smoke for a rocket launch sequence. I imagine it to be simple for an experienced Houdini visual fx artist, but I am very very new to Houdini and am having trouble with a couple of things. My renders come out super blocky and low-detail for some reason. I'm sort of in a desperate situation where I just need some detailed billowy smoke flowing out one source, as seen in a standard rocket/shuttle launch. Can anyone assist me with this? Any help/wisdom/knowledge is much appreciated, and I apologize for such a beginner question. Attached is the project file of the volcano preset I tried to transform into the billowy smoke.
Rocket Smoke.hipnc (756.9 KB)
I'm pretty sure your problem is the division size parameter on the pyro node in the AutoDopNetwork. Pyro and smoke effects have a default division size of .2. You increased the value to 1, probably for ease of playback. Unfortunately this has a drastic effect on both the movement of the simulation, as well as the appearance. I changed the value to .2, and the effect was a lot better. Experiment with these values to find one that works for you.
Cheers
