MartybNz
You should download Houdini Apprentice, it's free! and let us know what you think.
The views on the topic also record the unregistered ‘lurkers’
I will try when I buy a new rig which would happen within a week or so. And for your second line, yes I should have considered that.
Andy58
BrecMadak .
So to start, I'm interested in learning 3d modelling program but don't have any idea which one to start with ! I'd like design characters in 3d environment realistically primarily. Not keen on animating them though. This is what I want to focus on doing so ! I've above average drawing skills and would like to combine my skills within 3d visuals. So it would make more sense If there is one program that relies more into in-depth possibilities in artistry and organic looking rather than dealing with crunching numbers etc.
From the above you should look at tools like ZBrush, 3D Coat, Modo and the like that are well established in organic modeling. Good luck.
Edit: Be aware that 3D tools tend to be more technical than a brush or a pencil ;-)
Heard various opinions from numerous users that use these 3 programs, no wonder. Some say Zbrush' UI is so complex, some say despite Zbrush is more widely known 3D Coat was almost better in many way, by being more flexible, voxel based etc.
For good and all, the most important things would that learning curve to not to be too steep and products as outcome to be organic as much as it gets. (Although its related to user's skills at some point)
Not sure but would it be wise to pull of one particular one out of the 3, as which one of them fits me best in this case ? Or should i spend some time on all of them untill I can point out one so which could only happen after buying a new rig ? Or should I be using them transformational like Zbrush for sculpturing and 3DC for texture painting f.e ? (would prefer using and advancing in particular one that could handle all, though)
Edit: I read this at most recent time:
http://3d-coat.com/forum/index.php?showtopic=14730 [
3d-coat.com] (particularly Psmith's posts)
What would you say about this ?
Cheers.
