When trying to run hkey, I get this error:
master1 : hkey
master1 : ERROR: could not obtain GLX visual!
Most likely cause is a lack of 3D acceleration. Check your configuration.
Never seen this before, anyone know what it's complaining about.
H7.0.212 | Fedora Core 2 | Dual Opteron 64bit machines
–Mark
hkey error (GLX visual)
6894 9 2-
- debragrace
- 543 posts
- stevenong
- 1634 posts
- debragrace
- 543 posts
Hi Steven,
I'm working on the machine remotely so I can't open the box and look in but /etc/sysconfig/hwconf has this entry:
class: VIDEO
bus: PCI
detached: 0
driver: Card:ATI Mach64
desc: “ATI|Rage XL”
vendorId: 1002
deviceId: 4752
subVendorId: 1002
subDeviceId: 8008
pciType: 1
pcidom: 0
pcibus: 3
pcidev: 6
pcifn: 0
There's no XF86config file on this machine, not sure why, still investigating.
–Mark
class: VIDEO
bus: PCI
detached: 0
desc: “ATI|Rage XL”
vendorId: 1002
deviceId: 4752
subVendorId: 1002
subDeviceId: 8008
pciType: 1
pcidom: 0
pcibus: 3
pcidev: 6
pcifn: 0
–Mark
- debragrace
- 543 posts
- stevenong
- 1634 posts
- debragrace
- 543 posts
OK, I got an answer (of sorts). The machine(s) I'm trying to get Houdini to run on is a cluster of 16 dual opteron's, but it appears the head node doesn't have 3D acceleration with it's built in gfx chip set on the motherboard. Since we're going to be using this as a render farm it's not necesary to run Houdini, just mantra, what would you recommend to get a license installed? I thought sesictrl used to allow you to install a license “manually” (i.e. without having to run hkey) but it doesn't seem to have that option anymore.
Here's what our tech contact person has to say:
The X drivers for that video card are installed. The XF86Config file
that you're looking for has changed to being called xorg.conf, because
most distributions have switched to using x.org (an XFree86 derivitive)
instead of XFree86.
When I try to run “hkey”, it returns the error message:
This would be expected since the graphics chipset that is included on
the master's motherboard doesn't have any hardware 3D acceleration.
–Mark
instead of XFree86.
–Mark
- stevenong
- 1634 posts
Hey Mark,
You can still use sesictrl to install licenses. This is the syntax:
sesictrl -I key_info
so do:
sesictrl -h foo.bar.moo -l SERVER foo.bar.moo 123456abc
Before doing the above, you might want to do
set noglob
to prevent the shell from expanding the license string.
Hope the above works for you.
Cheers!
steven
so do:
set noglob
Cheers!
steven
- debragrace
- 543 posts
stevenong
Hey Mark,
so do:
Ahh, it's still there! From what I remember you used to be able to give sesictrl a license (text) file. I'll give it a try soon (need to get a proxy setup on their firewall).
Thanks Steven!
–Mark
- stevenong
- 1634 posts
- old_school
- 2540 posts
You can generate your license by providing the license machine's server code and machine name. This is the way licensing used to happen before we automated the process through the entitlement system.
Using the email that we initially sent you with the name and password, you can log in to license.sidefx.com and issue yourself a key. You will get in return the license key line. Just use that to install the license manually in the shell.
