I have successfully set up a GLSL shader that reads a texture from disk with texture2D(<textureparametername>, pos.yx).
I would now like to read a 3d texture but I am unsure if Houdini even supports this with its user end GLSL shader builder, or what file format that I need to use.
I have tried adding the following lines:
uniform sampler3D texture; //texture being the name of my parameter that points to a bgeo volume, image or whatever the correct input format is)
float test = texture3D(texture,pos.xyz);
I do not get any errors but I get a value of zero back, regardless of where I set the pos.xyz value.
Because it is error free, I am assuming the problem is one of two situations:
1. It is supported but I am not using the right file format. (I tried bgeo and a single tga, I even looked into i3d, God help me)
2. It is not supported and the error is ignored in Houdini itself.
My question is this: If it is supported, what format do I need to use? Also is there anything else I need to do differently?
Again, i have a working case of a texture2D sample of a tga file. Also, I made sure that the 3dViewport was set to gl 2.1, which is the version of the GLSL shader that I am working with.
GLSL Shaders - using 3d textures
3363 1 1-
- aschneider
- 80 posts
- aschneider
- 80 posts
