Hi There, I just started learning houdini and the apprentice x64 version keeps crashing when i get to a part of the first tutorial. At the point where you make the pillar breakable, it crashes everytime I hit play.
I've tried checking the forums and tried these to no avail.
- i've switched the solver from BULLET to RBD
- tried the 3d perspective view to 3.3, 2.1, 1.1
- double checked for bad poly's on the pillar
- i also just built a new scene with a ground plane and a sphere that was
made and rbd object then made it breakable and dropped it on the ground.
Is there something i'm doing wrong when assigning the dynamic objects? Or is there some setting I don't know about still….? sucks that i'm stuck on tutorial 01 .some help please =]
Tutorial 01 crashes on make breakable
3797 7 1-
- jyaw
- 7 posts
- anon_user_37409885
- 4189 posts
- jyaw
- 7 posts
Specs:
32gb RAM DDR3
win7x64
ATI Radeon 7970FX
Houdini FX version. 13.0.509
amd catalyst ver. 14.4
Using a sphere thats been made a rigid body object and had make breakable applied to it.:
solver - RBD
3d viewport - 1.1
5944: Fatal error: Illegal instruction
Saving application data to C
Users/BOWSER/AppData/Local/Temp/crash.test.01.BOWSER_5944.hip
3d viewport 3.3
6280: Fatal error: Illegal instruction
Users/BOWSER/AppData/Local/Temp/crash.test.01.BOWSER_6280.hip
columns tutorial :
solver RBD
3d viewport - 3.3
7108: Fatal error: Illegal instruction
Users/BOWSER/AppData/Local/Temp/crash.tut_columns.03.BOWSER_7108.hip
Sorry i'm not familiar with the terminology. Hope this is what you're talking about.
32gb RAM DDR3
win7x64
ATI Radeon 7970FX
solver - RBD
3d viewport - 1.1
Users/BOWSER/AppData/Local/Temp/crash.test.01.BOWSER_5944.hip3d viewport 3.3
Users/BOWSER/AppData/Local/Temp/crash.test.01.BOWSER_6280.hip===============================
columns tutorial :
solver RBD
3d viewport - 3.3
Users/BOWSER/AppData/Local/Temp/crash.tut_columns.03.BOWSER_7108.hipSorry i'm not familiar with the terminology. Hope this is what you're talking about.
- edward
- 8171 posts
- jyaw
- 7 posts
- edward
- 8171 posts
- jyaw
- 7 posts
- jyaw
- 7 posts
