Path Deform HDK Plugin
   20193   35   3
edward
Ali Tezel
Isn't VC9 32 bit only?
I'm not sure why the “Download Houdini” link only offers VC9 32-bit or VC11 64-bit. If you're logged in and use the Download > Daily Builds link, the actual choices are: VC9 32-bit, VC9 64-bit, VC11 64-bit.
For the next major version of Houdini, the choices will be: VC11 32-bit, or VC11 64-bit . We're really close to being able to drop the VC11 32-bit builds as well since the 32-bit builds for all non-Windows platforms have already been dropped.
Might be subject to change.
Ah thanks for the explanation. What exactly is the difference between VC11 and VC9 then?
Ali Tezel
Microsoft individually versions all of their compilers which then get marketed under the Visual Studio umbrella. So VC9 is Visual C++ version 9, which was sold with Visual Studio 2009, while VC11 is Visual C++ version 11, which was sold with Visual Studio 2012.
The big reason why we're switching over to VC11 is because the Houdini code base has started using C++11 features, which the older compiler doesn't support.
http://en.wikipedia.org/wiki/Visual_C%2B%2B#32-bit_and_64-bit_versions [en.wikipedia.org]
edward
Ali Tezel
So Houdini will be only release for VC11 ASAP and I should switch to VS 2012 for HDK , right ?
Rabiee.Sadjad@Gmail.Com
Yes, I would recommend upgrading to VS2012.
edward
Really Thanks edward for your great note 8)
Really thanks Stalkerx777 for this great tool.
I really like your method for path deforming.
I made similar tool with VEX , of course with some little changes and optimizing for VEX language. 8)
Download :
http://www.orbolt.com/asset/Sadjad::JK_PathDeformer [orbolt.com]
Cool plugin!
But the error:
(hsvg.exe:10988): Pango-WARNING **: No builtin or dynamically
loaded modules were found. Pango will not work correctly.
This probably means there was an error in the creation of:
‘E:\PROGRA~1\SIDEEF~1\HOUDIN~1.567\hsvg\etc\pango\pango.modules’
You should create this file by running pango-querymodules.
Fontconfig error: Cannot load default config file
No fonts found; this probably means that the fontconfig
library is not correctly configured. You may need to
edit the fonts.conf configuration file. More information
about fontconfig can be found in the fontconfig(3) manual
page and on http://fontconfig.org [fontconfig.org]
Generating new icons…
Done generating new icons.
Russian Operating System Windows 7 x64
Joker386
Download :
Thanks. Thats cool, now we have 2 implementations to choose from :wink:
Cool plugin!
But the error:
Code:
I thinks this warning message is unrelated to plugin.
Aleksei Rusev
Sr. Graphics Tools Engineer @ Nvidia
Yes , Exactly 8)
I was searching for some method for deforming a geometry (specially a Helix) , along a curve , Then I found your Plug-ins , I knew that your method was really perfect for my project .
:wink:
Great thing! I suggest SESI should integrate this function in new version.
Tanks a lot! works perfect!
So with the shift to VC14 for H15.5, Mr Rusev's plugin is due for recompilation?
FridayMarch27th
Probably. Also, I'd strongly recommend using Update 1, not Update 2 or 3, because 2 has at least one terrible bug where the compiler generates incorrect machine code, (e.g. it sometimes failed at finding the bounding box of two points), and 3 has some internal compile error bugs. The public builds of Houdini 15.5 are built with Update 1, so it might also be necessary for binary compatibility.
Super thanks for this, most appreciated. A big help.
fyi when used with a carve before the curve I get a crash if the carve reduces the curve to 0 but a clamp to 0.001 on the value fixes that.
Rich
Richard Costin
It looks like there's a bug on line 328 of sop_pathdeform.cpp [bitbucket.org]. If there are no primitives in the input, it'll probably crash, because there is no primitive index 0 to request the offset of. It should be checking curve_gdp->getNumPrimitives() to make sure that there's at least one primitive.
Also, calling geocurve_prim->getPointRange().getEntries() is probably the second-slowest way I've yet seen to determine the number of vertices in a primitive, (the slowest being a case where someone actually made the GA_Range only to iterate over it incrementing a counter). It really makes me want to remove that function altogether, because it keeps giving people the false impression that it's the right thing to use and it's almost never the right thing to use. The best simple way to iterate over the vertices of a single primitive is currently something like:
for (GA_Size i = 0, n = prim->getVertexCount(); i < n; ++i) {
    GA_Offset vtxoff = prim->getVertexOffset(i); // If you need vertex offsets
    GA_Offset ptoff = prim->getPointOffset(i);   // If you need point offsets
I'm adding something like the following for the next major version of Houdini, so that you can use a lambda and avoid a little more overhead, though I do appreciate that lambdas can be pretty scary at first.
prim->forEachPoint([put bindings here](GA_Offset ptoff){
Hi, thanks for sharing this plugin. I just wanted to note that to compile on Manjaro 17.1, I had to change line 36 of sop_pathdeform.cpp from:
const char *inputLabels = {“Deform geometry”, “Input curve”, ‘\0’};
to:
const char *inputLabels = {“Deform geometry”, “Input curve”, “\0”};
Otherwise, make would say there was a invalid cast from “const char” to “char,” or vice versa. The plugin loads and the example scene seems to work fine with this small edit…
Would that small change affect builds on the other platforms (Win/Mac/Etc)?
