question about instance and copy
   5760   4   0
Copy sop creates copies, but not instance, besides point instance in houdini, is there another way to achive instance?
btw, if Copy sop can create instance, it would be better…..
^_^
Hey Man,
I think there is an instance sop. I believe if you just type instance it will come up. What version of houdini are you using ? That might matter. I can not double check myself until later today. I am just trying to go off of memory right now.
Nate Nesler
I updated this page too:
http://www.odforce.net/wiki/index.php/MantraInstancing [odforce.net]
Jason Iversen, Technology Supervisor & R&D Lead @ WetaFX
In the Point SOP, under the Particle tab, the last entry should let you add references to instance objects.
George.
thank you
^_^
