distributing spheres on a surface without overlapping
   9638   6   3
Hi there
I'm creating some animations on how virus's interact with our evolutionary tree and came across this image of a virus. Basically a sphere with a whole load of evenly spaced random sized sphere's stuck on that don't overlap.
There are some ideas in here http://forums.odforce.net/topic/19771-tesselating-spheres/ [forums.odforce.net]
Hi there eetu
thanks for the link , I'm investigating your projects now and trying to adapt your methods to a sphere.
Just from playing a little - your method is to distribute using the voronoi fracture and scatter sops , then measure the area of the polygons and place a circle at the centre of each poly scaled on the area ?
thanks
John
Yeah, and here's another test with remesh&subdivide, to try and get a bit of that semi-regular stubby look.
ee_spike_sphere_scatter.hip (120.4 KB)
Eetu that is excellent!
I've had a look at the scene and it's a very elegant idea , using the way the geometry meshes to get a pleasing pattern .
I've been having fun with the voronio noise to get some patterns but am finding the scatter sop a bit limited to create the points based on the noise.
I think it needs a more uniform scatter based on the noise
here's my efforts
John
BTW my hip file uses the csUniformScatter.otl
JB_spike_sphere_scatter03.1.hip (328.1 KB)
Maybe you can get some ideas from that:
http://julianjohnsonsblog.blogspot.de/2013/07/dart-throw-multiple-size.html [julianjohnsonsblog.blogspot.de]
Its ICE and I don't know if it is in any way transferable to Houdini, but it may be an inspiration.
thanks for the tip mr bigtree
That looks like just what's needed , it seems the technique is called ‘dart throwing’
searching under those terms I've discovered an old conversation about the same subject were someone's attempted some Vex code to do this
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=96672 [sidefx.com]
and also this discussion
http://www.sidefx.com/index.php?option=com_mailarchive&Itemid=212&view=WEB&msgid=48DAAF14.9050006@axyzfx.com&perpage=20&revdate=on [sidefx.com]
thanks
John
