Hi, first post here. I searched a bit on this question, but haven't come up with any clear answers yet.
Houdini version is 13.0.509-win64-vc11.exe
I've built opencv using Visual Studio 2012 ( (x86)/Microsoft Visual Studio 11.0/VC/bin/x86_amd64/cl.exe (ver 17.0.50727.1) ), and installed the resulting cv2.pyd in Houdini's python2.7 site-packages directory.
To be clear, I used the .sln solution file generated by cmake, per the opencv Windows build instructions provided at opencv.org and was sure to point it to the appropriate Houdini python location, etc…
In Houdini, the module *seems* to attempt to load (doesn't complain in the usual “no module named <blah>” way), but then I get an ImportError: DLL load failed: The specified module could not be found.
It's worth pointing out that I'm having the same issue with my Anaconda python install, so this isn't specific to Houdini python. Nonetheless, I'm putting the question up here since I figure you guys on Windows must be trying the same sort of thing I'm attempting.
Any ideas what to do next? I'm new to using Windows, used to linux and OS X so not really sure what else I need to be checking for.
Thank you in advance for your time.
Building python modules for Houdini 13 on Windows
5196 6 1-
- Jay Reynolds
- 4 posts
- edward
- 8053 posts
Try running Houdini under the Dependency Walker [dependencywalker.com]. This used to be a tool distributed with Visual Studio until it branched off. Maybe some of the errors that occur while loading your .pyd might give you some ideas.
- Jay Reynolds
- 4 posts
- Jay Reynolds
- 4 posts
- dulo
- 383 posts
- Jay Reynolds
- 4 posts
Hey, sorry to revive a necro'd thread, but I finally got numpy 1.9.x to build with the Intel Math Kernel Library (BLAS/LAPACK functionality) using vc11 and the Intel Fortran compiler.
Please see:
https://software.intel.com/en-us/articles/building-numpyscipy-with-intel-mkl-and-intel-fortran-on-windows [software.intel.com]
Got it built and installed to hython with no problems. Tests verify correct operation and that MKL is being used, etc…
Next, I built scipy and installed it as well. Looking pretty good… zero erros in “fast” test mode. However, 8 errors in “full” test mode, but I'm working on it.
Please see:
- dulo
- 383 posts
