Curve Offset Tool
   18344   27   1
We have a useful tool in Maya to create new curve with some offset to base curve , It's Curve Offset.
But I can't do it in the Houdini with Peak SOP , How can I do that ?
Thanks.
You can use Extrude SOP , Just you should use “Thickness Offset” parameter instead of “Depth Scale” !
Rabiee.Sadjad@Gmail.Com
This is a example file with more features 8)
JKCurveOffset.hip (66.0 KB)
Specially thanks Sadjad with your fast reply :shock:
I have another question , How we can do that with Peak SOP ?
Why it can't do that correctly ?
The Peak SOP using Normal vector for peaking points , so you should first compute your normal vector correctly. :idea:
This is another example about how you can use Peak SOP , Of course it can't offset your curve perfectly for large amount of offset ,it's just for learning :roll:
JKCurveOffset_Peak.hip (75.6 KB)
Thanks again sadjad for your helps 8)
Jack.N
:wink:
Sorry guys for my many questions , But I have another question.
I working on some different projects about working with curves and path (like Offset Tool).
for now I like to know what's method can be use for Curve Deformers ?
my meant is deforming a geometry on the curve.
In Maya we can do this with Motion Path and then using Flow Path Object.
But in the Houdini we don't have same tool , Of course I found some similar tools in the Orbolt3D , But I l wanna know how I can do that manually ?
specially thanks
I'm not sure about another methods , But I'm familiar with these two methods :
1. Using Lattice
2. Using Curve Attributes
A : in the first method we can use Sweep SOP to copy some primitives on the curves (usually they are simple grid) , So now we can use them as Lattice shape , It's like a Box that deformed like your curve , Then we should use Lattice SOP for deforming original geometry by this Deformed Lattice shape.
The best example about this method is PathDeformer Tool in the Orbolt from Animatrix.
I think Maya use this method for Flow Path Object , Because Maya add Lattice Deformer on the Curve after using this tool.
Although this method is simple But I think the second method is better and faster than first one !
B : in the next method you should compute some attributes for your curves such as : Up vector , Tangent Vector , B Tangent Vector
Then we should compute relative position of each point from source geometry to curve's point , Then we copy curve's attribute from nearest point on the curve to each point on the source geometry.
finally we can use these 3 vector attrs for rotating points of the source geometry.
NOTE : we should put these attrs in the Matrix , then multiply this Matrix by point's position of the geometry.
in the final step we should add position of these new rotated points by curve's points position.
this method is really faster than first one and you don't need to any additional nodes like Lattice or Sweep.
This is a great HDK plug-in from Stalkerx777 that using second method :
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=34005&highlight=Path+Deformer [sidefx.com]
And this is animatrix HDA from Orbolt library :
http://www.orbolt.com/asset/animatrix::pathDeform::1.00 [orbolt.com]
Woooooooooow :shock:
Specially thanks for this perfect answer Sadjad :roll:
Your are one of the BEST
Jack.N
ops:
Of course it's complex for me and I should learn more about Houdini :roll:
Jack.N
Everyone should learn more about Houdini , Houdini is a really infinity software :!:
with polyframe
offsetCurve.hip (58.7 KB)
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
Joker386
Thanks for the plug mate
Btw there is also Offset Curve SOP:
https://www.orbolt.com/asset/animatrix::offsetCurve::1.00 [orbolt.com]
pusat
Joker386
Yes , This tool is great too , like others. Thanks
buki
with polyframe
Yes , That's abusive using PolyFrame SOP is better than last method , thanks
