Error in Open Houdini Indie in Houdini FX !
   8751   6   0
I try to open hiplc file in the Houdini FX , But I take error message.
Maybe we can just open hiplc files in the new versions of the Houdini , right ?
I using H13.0.401
.hiplc files cannot be used with the full commercial version of Houdini. However, I recall in the past that Side Effects would convert your Apprentice .hipnc scenes to the .hip format if you upgraded to a full commercial license, and I assume they'll most likely do the same for .hiplc scenes as well.
I poked around a bit but couldn't find a reference to this service on the site… I'd try contacting the support team and see if they can point you in the right direction.
shouldn't opening a Houdini Indie scene file in Houdini FX turn that session into a Houdini Indie session?
as would happen with Apprentice?
Training Lead
www.sidefx.com
It should work - H13.0.401 is most likely too old, before Indie was released I believe - try the latest builds.
arctor
I think you won't be getting an indie session unless you have an indie licence, regardless of having an fx license.
In H13.0.545 an Fx license reverts to Indie license
A dialog will appear as you open the file
Screen Shot 2014-10-21 at 3.51.14 pm.png (22.9 KB)
MartybNz
Cool, didn't know that, thank you.
