single RBD piece affecting multi-piece Object
   3803   3   1
Hi everybody,
I have a scene, say many lamps, that have many pieces but I only want to use proxies to affect the lamps. So instead of simming multiple pieces per lamp, I want sim one piece per lamp(like proxies), affecting the multi-piece lamps by the proxies from my RBD sim. What is a good route for that?
Thanks in advance.
svenvfx
Hi everybody,
Thanks in advance.
Im reading over and over again, but have no clue to what you are trying to do.
You got a simple .hip?
Sorry for being confusing. ops:
I've attached the hip and alembic file for you to dig in.
Hope this is helpful.
-Steven
coffeeCupRBD.zip (54.3 KB)
Now I get it.
I`ve never used the transform pieces SOP, so someone might chip in on why it doesn´t pick up your coffecup based only on the name attribute.
However…
Set the object mask on the dopimport node to rbdpackedobject1 and it works.
*edit. I have messed around with the scale in the returning scene.
coffeeCup_RBD_002_SC.hipnc (286.2 KB)
