License Server Problem
   16433   8   1
When I start houdini I get a small window saying that it is connecting to the license server and it stays like that for 20 minutes now. Anyone have this problem?? Anyone have a solution?
Dual Xeon Processors. 1GB ram. Win2k
Have you got your license yet? Or are you trying to get your license?
Are you using a proxy server to connect to the internet? If you are, you can set it in hkey under File -> Preferences. Check ‘Use HTTP proxy’ & then enter the proxy server information there.
Cheers!
steven
Well It's been almost 3 hours now. :cry: I uninstalled it, and rebooted and reinstalled and rebooted. I only get a small window That says Connecting to License Server. with small balls animating on a black bakground.
This is the Apprentice Edition.
Are you able to get your license during the installation process?
Also, which Service Pack are you using? Internet connection with DHCP? Or a dial-up connection?
Did you get the Connecting to License Server window when you try to start Houdini?
Cheers!
steven
Allright. I am using the Apprentice Edition of Houdini
I didnt get a license during Installation (should I have?)
I am using SP3 for win2k
I get the connecting to license server window when I try and start anything in Houdini.
I uninstalled again rebooted, logged in as administrator, reinstalled Houdini and rebooted.
I can get into the License administrator as admin, but when I go to get the key, it says my email and password are incorrect.
When I try and start Houdini as myself (have admin privelages) I get stuck.
Help please!
thanks - adam (eager to get houdini-ing!)
Login as admin & try to get a license again. Did you forget the password?
If you got everything right, please start the hkey's diagnostic tool by going to View -> Diagnostic Information…
In the ensuing window, please click ‘Save…’ to save the information to a text file. Then post the information here.
Please let me know how it goes.
Cheers!
steven
Here is the output of the Diagnostics:
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Thu Aug 08 08:32:00 2002
Local host name: NHGCLIENT55
Local server code: 232036b3
Local ip address: 127.0.0.1
License server name: nhgclient55
License server server code: 232036b3
Server ip address: 127.0.0.1
License server is running: Yes
Has SERVER license: No
License server version: 5.5.36
May modify server from this machine: Yes
License Administrator version: 5.5.36
Http proxy host: (none)
Using standalong mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
—– SERVER nhgclient55 ——–
*** WARNING *** - No valid server lines found
hserver -l output:
Hostname: NHGCLIENT55
Uptime: 15:26:40
License Server: nhgclient55
Server Version: sesinetd5.5.36
Version: Houdini5.5.36
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
673 of 1023 Mb available
CPU Usage: 0% load
0 active tasks (2 slots)
licenses file:
* Could not open the licenses file. *
I did not get a password. The License manager mentioned something about Houdini Online Services I cant find any reference to that on the Houdini website. Maybe that is the key??
Thanks, adam
I figured it out.
I launched Houdini from the Admin account and installed a non-commercial license, as opposed to just launching the License administrator. I got the license installed logged back in as myself and im off!!
Thanks for your help.
–adam
I don't think I was any help but…
Woohoo!!! 8)
