pesky 1.#INF values showing up on floats?
   4308   8   1
hey guys, has anyone seen these weird values show up on floats after passing through an attribVOP that divides the sum of the values of a for loop by their count (i.e. average) ?
it seems very sporadic and causes sometimes this attribute to be invalidated in my next operations which is bad
any help to avoid or work around this issue would be appreciated!
-G
update - this seems to happen even after the for loop “sums” my float values ): division does not seem to have anything to do with it
-G
Did you try this?:
http://www.sidefx.com/docs/houdini13.0/nodes/vop/isnan [sidefx.com]
OMG thank you… I am going to give that a whirl for sure.. did not realize there were vops to handle NANs..
-G
look at that… there is even a “is finite…”
thanks man!
-G
Glad it worked
I don't think VEX should “produce” NANs if they didn't exist from the input. So double-check that your input values don't have NANs first. If they didn't, then I'd almost say it's a bug in VEX.
i'll double check my attributes but I think the non real number surged after summing the distance in between a point and all its neighbours inside a for loop. It also seems to oddly sometimes show up and sometimes not show up which is weird (but when it shows up, it “breaks” my attribute creation ): )
-G
ok upon further investigation, it seems like the infinite (1.#INF00) are being generated by the import into the for loop VOP (most likely since the index in my result screenshot is set to 0) OR potentially when calculating the distance in between this point and the neighbour points. it always seems to happen at the first iteration though
I suspect there may be a bug in the subinput VOP or the distance VOP that can sometime cause infinite numbers?
now that I can catch this, I am going to see if I can gracefully recover from it
thank you for the help!
-G
