What is Particle System Primitive?
How useful about it?
What ‘s different with point group?
I can’t find some document.
3606 5 1-
- jerry7
- 680 posts
- edward
- 8081 posts
- old_school
- 2540 posts
100% with Ed. No need for old school users too to use the Particle primitive either.
It is far more efficient to deal with raw points now. No primitive attribute overhead. Everything that was edge cased to particle primitives including auto-instancing spheres/tubes/sprites/etc. are now easily supported on raw points.
Don't use the particle primitive.
- animatrix_
- 5100 posts
I thought there is one reason to use particle primitives and that was to show points as guides for an HDA. Is there an alternative for this?
- old_school
- 2540 posts
- animatrix_
- 5100 posts
You are right Jeff, it does work. I thought you needed a particle system to make sure points show up as guides. I just tried and having plain points in the guide gives you a lot more flexibility than a particle system ironically as the Display Options for particles allow you to customize plain points this way more so than a particle system.
