Fancy seeing some of your familiar faces here!
I am doing some VDB work in Houdini and transferring it to C4D.
Everything works with Arnold with no problems, although the volume bounding box preview is a bit flaky…
However, I have one question which I cannot seem to find an answer to.
Do the visualizations inside Houdini, that end up getting transferred to C4D
via the VDB file GET CHANGED BY THE REMAPPING SETTINGS in Houdini?
Or, as I suspect, does it just change how it is visualized within Houdini, and the actual data (Temperature, Heat, Density, etc.) still have the same values
no matter what settings I adjust in the Visualize tabs in Houdini?
If that is the case, how might I make a custom field that can be passed to the
VDB that has nothing to do with the volume simulation, but rather will be used within C4D when rendering with Arnold?
Does that all make sense?
Thanks for any help you can supply.
Perry
