How to save otl as another type?
   3681   3   1
I have some otl types. I want change some nodes inside and save to another otl type. But it seemed the operator type can't be changed. How to save as another type? Copy all node inside to a new position may cause many reference problems.
you should be able to change it in the Type Properties.
Right Click on the Node and on the bottom select Type Properties. There you see Save to Library.Chose another destination to save. And voila.
otherwise why not use switch node ?
In Windows -> Manager Asset Libraries, if you right click on an asset there, there's a menu for Copy. That will allow you to copy the asset and chooses a different asset name (i.e. type).
Andrew / アンドリュー
Thank for replies!
