I am following a tutorial using “old” popnet, which is using a curl noise in the network… Now, I am trying to use the newer popnet instead and not sure how to introduce curl noise to the network….
I have tried pop vop to mimic the look but I don't know how to make it to work associate with “Time Varying” and “Pulse Duration” in the curl noise that old popnet has…. Anyway I can make it happen?
Thanks for your help…
How to introduce curl noise inside the newer popnet?
4083 1 0-
- booger
- 32 posts
- mawi
- 253 posts
booger
The pop force node use curl noise.
If you for some reson want to build your own, dive into it to see how its constructed…
