UV Image Export size...
3663 4 2-
- CGS
- 59 posts
- DASD
- 490 posts
If you tell me how you do it, I can test to make sure, but I think there's no limit for still renders on Houdini Indie.
http://www.sidefx.com/index.php?option=com_content&task=blogcategory&id=219&Itemid=382 [sidefx.com]
- CGS
- 59 posts
DASD
Just create a box, dive into the box SOP lay down a uvunwrap node then right click on the uvunwrap node, select save and then Texture To UV Image. A box pops up allowing you to set the size, name and location of the image. For me using Apprentice it only saves out images up to 512x512. If I set the size to 1024x1024 it will not save anything out.
Edited by - Dec. 9, 2015 10:54:40
- DASD
- 490 posts
- CGS
- 59 posts
