I am trying to store my primitive group name in a variable in VEX and I would like to do it in a procedural way something like:
s@name = @group_*;
Off course this doesn't work, any tips?
Thanks.
Store group name in a variable
7203 7 1-
- mzigaib
- 1048 posts
- tamte
- 9564 posts
You can use Name SOP for this, but if you need more flexible way here is how to get all point groups that point belongs to
http://forums.odforce.net/topic/23822-how-to-get-the-group-name-from-points/?p=140187 [forums.odforce.net]
So just change it for prim groups
- mzigaib
- 1048 posts
- Cicuta
- 104 posts
I am surprised to see how old this topic is and there is still no function in VEX that could achieve it. Something like isgroup() where you feed a string and it returns 1 if it that group exists and the point/prim/vertex is in the group, 0 if it exists but it is not in the group and -1 if it doesn't exist.
Is there something I am missing on why this function is not a good idea? Or is there already a function that can achieve something similar?
- ObeidaZakzak
- 137 posts
Cicuta
It is exactly what these functions do, except for the -1 for group existance, it will be 0 in this case :
inprimgroup() [www.sidefx.com]
inpointgroup() [www.sidefx.com]
invertexgroup() [www.sidefx.com]
Edited by ObeidaZakzak - Feb. 16, 2024 13:53:05
- animatrix_
- 5185 posts
You can use the detail intrinsics for the groups.
Same for pointgroups, edgegroups and vertexgroups.
i@found = 0; string groups = detailintrinsic ( 0, "primgroups" ); if ( find ( groups, "group1" ) ) i@found = 1;
- tamte
- 9564 posts
- Cicuta
- 104 posts
tamte
both of which are already mentioned in above links so I'm not sure what this missing VEX question is exactly about
I think I wasn't too clear about what I was looking for and for some reason I got mixed up the link in your first reply with a different post about the same topic that gave a python solution.
animatrix_
You can use the detail intrinsics for the groups.i@found = 0; string groups = detailintrinsic ( 0, "primgroups" ); if ( find ( groups, "group1" ) ) i@found = 1;
This was what I was looking for and indeed it is also explained in the link you provided.
Thanks and sorry for the missunderstanding!
Edited by Cicuta - Feb. 16, 2024 19:29:01
