Hello.
I just made a simple setup of fractured and glued object. Now I want to un-glue fragments that are virtually touched by a sphere. I'm using Group node to get glue points inside the geometry, then color it into white color (just to check if everything goes right) then delete points. But this method only involves points that are inside the geometry in current frame. Once the geometry moves further, gluing nodes are recovered. I attached gluing subnet and scene view. Would apprectiate any help. Thanks.
P.S. Changing group operation to "union with existing aint working
Permanent point deletion
3259 1 0-
- Scarecrow
- 1 posts
- Enivob
- 2660 posts
Don't use a DELETE node, use an Attribute Wrangle instead. Inside the Attribute Wrangle use the vex code like so…
if (@Cd.r == 1.0) {
// We detected white color.
removeprim (0,@primnum,1);
This way you are removing the primitive reference geometry, line and points all together.
Take a look at the removeprim function in the VEX documentation.
if (@Cd.r == 1.0) {
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
