Add points to a curve in the edit node
   5724   2   1
Hi there,
Just trying to get some basic stuff working with curves and I'm running into some problems.
Because you cant multi edit points from the initial curve node, I've added an edit after it to move things around easier but now I can't seem to add points and refine the curve? Is there a way to do this?
Pete
you can try the Resample SOP - this will allow you to change the number of points in the curve.
Training Lead
www.sidefx.com
Thanks, but I'm not sure that will work for me since it will change the amount of points overall and offset existing point positions. It's a shame there isn't a way to multi select points on the original curve node, that's the only reason I'm using the edit node really.
Oh well I'll just have to make do for the moment.
