Table Import modify P based on csv order
   2857   1   1
I use a table import SOP and a point sop to create a group of points. Since, the imported CSV file does not have x,y and z fields, Px, Py and Pz are all zero.
I want to modify point positions, based on their order in the CSV file.
For example, if there are 100 lines in the CSV and I want the points to be positioned 10 rows by 10 pixels.
I know I need to create a multi line expression. CMD E on a mac. I use python.
I can do the for each loops, but I don't know how to reference all of the points in order. I can't even get the following code to work.
count = 1
return count
Brad Carvey
Brad Carvey
Point Wrangle:
int cols = int(ceil(sqrt(@numpt)));
int col = @ptnum%cols;
int row = floor(@ptnum/cols);
@P = set(col, row, 0);
you can replace, int cols … line with any number of columns you want
like int cols = 10;
int cols = int(ceil(sqrt(@numpt))); just tries to keep your grid squareish
