I created a digital asset which works as intended from the hip file used to create it.
However, when I import that digital asset into a “blank” houdini hip file the digital asset does not respond to some parameters as it does in the “original” hip file.
There is only one digital asset file with only one name ( no copies or different versions were made along the way ).
I was hoping someone might be able to suggest trying something to save me much work of creating the digital asset from scratch again. ( I'm hoping the file isn't just “bugged out” ).
I'm not including the file because it's very large ( in terms of parameters - using about 2100 transferred from the digital assets within itself )
Thanks for any suggestions.
Imported Digital Asset not behaving same as Original
2219 0 1-
- BabaJ
- 2185 posts
