Basically there are 3 issues.
- Click a node will not select it, I have to draw a box on the node to select them properly
Click in in the top “address bar” to jump to an upper level from inside a node will also not respond properly. it will behave as if the LMB is continuosly pressing.
And a minor one is that on 2 screen I need to restart the wacom driver for the tablet to map the monitor correctly on Houdini, all other programs work fine.
All this are minor inconveniences so I was wondering if anyone out there also experienced this and if any solution or maybe setting fix is known.
